Ok took a few pics tonight, still yet to finish but got a lot more done and think we figured out the small led sizes.
Roof controls done, took 6 3mm leds.
Climatronic controls
First pull your face plates off
Then remove the 4 torq scres T20's 2 on sides 2 on bottom
Airbag clip, this is a plcc-4 led in the airbag light. U don't have to remove clip to get climatronic but it makes it way easier.
Once climatronic is out there are 6 or 7 torq screws T20 again,
Now when you begin to pull them apart make sure the circuit board is stays connected to the knob/button side. Back should slide off leaving circuit board.
Once you get to this you have 2 tabs to push outward to release the blue tooth module or what ever it is.
This is with it in.
With it out
With this out the circuit board comes right off....
With it off you can see the tons of lights there are approx. 35 plcc-2's and 27 0805's (not positive yet but measurements seemed right)
Hope this helps
