syonxwf
Rather than rise a necro thread from 2-3 years ago, I'm going to make my own because it makes me feel all warm and fuzzy inside.
Just went K04 last weekend, and I appear to have valve float, but want to see if there is anything else I can try before going the spring route. I have not had a chance to physically check my springs yet, that's saved for last because I don't want to pull my shit apart at the moment.
The vitals and important info:
2013 GTI, though the engine was replaced at 1800 miles (I don't feel like explaining that one right now) - significance here is that I don't know what motor they put in my car, but I do however have an updated tensioner (visually confirmed), if that makes any difference.
69k miles
Carbon cleaning done at 60k
New OEM Bosch Coil packs within last 500 miles
New NGK Plugs (the ones that start with B and I'm too lazy to search) gapped to .024 per APR, less than 200 miles on them.
Recently replaced LPFP control module due to an issue where the car would start and then drop to 500rpm and die, unless I feathered the gas, at which point it would come back up and drive/idle fine. I have read that the LPFP can be damaged if the control module isn't working for a while, though mine was only a couple weeks...I have yet to replace the LPFP because I don't think throwing money at the car will help, and I'd rather use that $350 towards valve springs.
Car pops and stutters from 5k-6k (I don't usually go much above 6.2k), and I only notice it in 3rd and 4th gear. I do not get any CEL's when this happens, and I was able to replicate it with T/C off - The significance of this is that I tried twice with T/C on, 4th gear pull, and the T/C light came on around 5-5.5k, but it most definitely does not feel like spinning/hopping when T/C is off, it feels like it's misfiring.
Prior to going K04, I was still getting some random misfires usually between 3-4k, this happening as recent as a week prior, but I couldn't ever get it to replicate reliably. This "misfire" feeling with K04 I also cannot replicate every time, only 50% of the time it happens.
Am I just an idiot and it's hopping in 4th above 5k, or is it most likely Valve float like I assume it is?
I got the low output file yesterday and it drives great again now and I have yet to notice any misfire-like feelings, but it's only been a day and it's been wet (so I haven't been able to get on it).
69k miles
