troutjunkie
So there's no need to run those wires to the cecm. There's no male end inside the midline cecm for them. But you can use them in the retrofit of the harness. You'll need to order four of the "small terminals" and six of the "male spade wire terminals" from ECS tuning along with their adapters. You'll also need some wire. Using the extra high beam wires from the harness and the new small terminals, you will make six new wires(three for each adapters)
Go back to the first couple of entries on this thread to see which new wires go where. The post was from pk440. Also there's a video on YouTube of how to "release" the inside of the adapters to allow the new terminals to be inserted. It takes a little time but you'll figure it out. Also, coding is covered in a link discussed earlier.
I ended up buying a vagcom from RossTech.
