I viewed another DIY on removing the RCD 510 which I have in my vehicle. Below I am going to show a few steps that may help others when installing this headunit.
Tools Used:
Small Pry Tool
T20 Torx Screwdiver
Completion Time:
~20 Minutes
Installation Steps:
1. Remove faceplate from headunit using pry tool.
http://imgur.com/a/QpyeJ
2. Remove the 4 T20 screws as shown.
http://imgur.com/a/Bj5Uq
3. At this point, the headunit will pull directly out. Disconnect the CAN connector and antennas.
http://imgur.com/a/fOEAA
4. Included in the packaging is an antenna adapter that you will need to use. View picture to see how it connects.
http://imgur.com/a/Dq6r2
5. Plug in CAN connector and antenna. Then mount headunit and install faceplate.
http://imgur.com/a/luDRD
NOTES:
- From scanning this thread if you have Dynaudio you must unplug/plug your car battery to get everything to function.
Quick question - I didn't see anywhere to plug the wire with the green connector into the new head unit. I just left it dangling and haven't experienced any negative effects. Did you find where this plugs in?
