1ashchuckton
They will use apple maps if you have an iphone & google maps if you are using an android.
Damn, Apple maps sucks. No way to use google maps with an iPhone?
So what CAN adapter do we need to avoid battery drain? I have a 2012 GLI.
It just shows a yellow bar at the top of the screen as you adjust volume. No number value and the MFI does nothing with the radio except display time.
thanks!No it doesn't.
Got a message from my seller on eBay and chatted with him via Whatsapp. He sent me a link to download an even newer version of the firmware. He said this has happened before. Minor language barrier.
He gave me the link below for the update to a onedrive account:
https://1drv.ms/u/s!Am8nQJSlrtIAbqYukWiRwvNr9Zw
Instructions to update as follows:
1. Download the file and save it onto a USB flash drive. Do Not extract it to the flash drive, just drag and drop from your computer.
2. Turn on radio and insert flash drive into the USB port on your radio.
3. Press and hold the SETUP key until you see UPDATE menu.
4. Select UPDATE and follow the prompts. Upgrade takes 6-10 minutes. Don't turn off ignition or power off stereo during upgrade.
5. Radio should restart itself and have the updated firmware.
Is there a firmware update for the 187b versions?
