They engineered a solution. You don't necessarily have to make your own parts to make a solution.
And I see it as a proprietary thing. Else someone else could just piece the kit and sell it as well. They never hid the fact that it was like stock solution. They aren't required to explain the part source.
Exactly. Why would they give away that information for free? So you guys could all go "try" and buy the same parts to get the same kit after all of their hard work?
They did not engineer or produce anything. They explained that through trial and error they found a combination of OEM parts that worked well for the needs of their customers and they buy and resell OEM parts.
They didn't engineer anything? I swung by when they were at there shop multiple late nights R&Ring different clutch disks, pressure plates, other things. They had a STACK of pressure plates and clutch plates that they tested to find the best thing out there. Do you think that's free? Maybe you should spend the money to do all of this and then come back here and tell us what the part numbers we should order are. How would you feel about someone taking all the time and effort you spent for free? Engineering isn't all CAD and shiny suits, it's mostly just trial and error. I know from experienece, and have worked multiple engineering jobs that were all just trial and error and see if it works. And I'll tell you this much, the items they are using are not just stock unmodified parts, and they aren't ones you can just go and order one of.
Companies do this all the time. It is consulting. Engineering is just solving problems man.
You can solve the problem yourself or pay someone to do it. In this case they do it for you and charge.
No one is stopping you from doing the research to determine the parts. All I am saying is they do not have to reveal the parts.
For your example, if I gave you the pencil and scratched out #2, you could buy pencils and figure it out, or just keep getting pencils from me.
This.
I don't see what the big deal is, it's not like the other "clutch" companies actually make anything for our cars either. SB / Clutchmasters just take fidanza / exedy flywheels, clutchnet pressure plates, and Sachs center sections, and slap a different friction disc on it, and then charge us $1300
This as well. Literally every other clutch manufacturer (like the people that only deal with clutches....) are just using a combination of PP's and disks from another car and at most designing a LWFW to bolt the stuff to.
