you have the right idea, but from my understanding they just want to make sure the pressure plate makes full contact with the disk. putting a tiny pressure plate on a larger disk is not the same thing as a smaller assembly. you'll increase wear for no reason. the disk should always match the pp, so in your example you'd want a smaller disk as well.
also you're assuming the tts plate is applying the same pressure over a larger area when it could be beefier to begin with.
Just want to say again and remind everyone that higher surface area will decrease holding capacity!
Haven't heard any specific comments to the contrary, but there seems to be a leaning in this thread that the larger contact surface of the TTS PP will be better than the TTRS. For wear, that may be true. I don't know. But as a general rule you can expect holding capacity to decrease proportionally to the contact surfaces in question.
Thanks for the measurements, I forgot to measure the TT-RS PP I looked at but so people know the differences, it's about 10mm(.4") difference between the 2
Nobody has said the TT PP was better than the TT-RS PP but it's the correct PP for the disk I'm using, plus the fact that I wanted to try something different, was the reasons I chose it(being ~$200 cheaper didn't hurt that decision either ). If it holds my Stage 3 setup, I'll be happy, if it doesn't, I can still replace the PP for the TT-RS and pay less than the RSR would of cost me, so there's no losing for me
...with the exception that you'd be doing the job twice, when you could have had it done RIGHT the first time by buying the TT-RS pressure plate and use IT as it's known to hold stage 3 easyly
What you say is true but if Caulkin's TTS presure plate holds and is $200 cheaper and matches the clutch disc diameter (for better wear IMO) how would you know if it works without a try?
May be HS tuning would know as some have reported they went trial and error with many OEM part combos and they may have tried the combo Caulkin is using.
IMO Caulkin is doing the same thing that HS tuning did and is reporting the results without grinding off OEM part numbers.
So what PP TTS or TTRS is the correct size for the stock gti disk? I may order the Audi PP to install with my DXD drop in disc
Trying to save $600 is worth 2-3 hrs worth of work to me plus like I've said, I like to try different things, wanna know how many shifters I've gone through :bellyroll:
dang you make like $200/hr?...lol j/p....thanks for helping the community out though, if your follow up reviews are good, ill be a follower too. makes me sad that i bought the RSR just a month before, but I am happy with it though.
