Here are the updates;
Installed the TurboZentrum EFR7163 kit after few modifications!
The kit didn’t fit directly because of the 1.5bar wastegate, so I had to remove the wastegate bracket and increasing the wastegate bolts location by 3mm, then install the kit and tight the wastegate after that.
Removed the bracket from turbo by losing the 3 red bolts;
And from the wastegate from losing the 2 green bolts;
As you can see there is small space between the wastegate bolt and the circle which reflect the 3mm has been increased.
Also, I had to shave the banjo bolt cone with the kit in order to make it fit. It fits but with only 1mm far from the WG but not touching it, I will replace it by the OEM banjo bolt as it is smaller and will fit much better.
It was very hard to install the 3.5” custom intake inlet because of the space but I succeeded at the end. Wish if I listened to Eric and have the air intake inlet 2.5” or 3” maximum!
Installed the K04 3” DP, wrapped the TP;
Installed the Milltek exhaust, I love it [emoji7]
I checked the spark plugs (after 24h from installing it) and I found it black which means the car running very rich!
This is how it looks now after installing all parts.
Now, I have problem with the car while starting in the cold start or even during the normal day. The car took too much time in order to start and then the engine turned off! It works only if I press the acceleration paddle for one minute (doing the cold start manually).
https://vimeo.com/251445781
The below parts are installed during the TurboZentrum EFR7163 kit installation:
- TurboZentrum EFR7163 kit
- RS4 injectors
- R20 intake camshaft
- IE manifold
- 3.5” custom air intake
- DM EFR7163 Revision file
Nothing more, nothing less and before that the car was starting quickly from the first key turn and very smooth with quite engine sound.
I did some VCDS checks and here the results:
The variation in fuel rail is very strange!
I even returned back the previous GTX file which was calibrated for S3 injectors and GTI camshaft and the fuel rail variation is still the same!!
What do you think?
All ideas are welcome!
