smanierre
Just realized this section would be more fitting for a built thread than the technical section so i'm reposting here.
I decided to document the build of my 2011 GTI. I bought it bone stock besides a subwoofer with 90k miles. I'll update the main post as I do stuff, although it will be a rather long build since I don't have the biggest budget at the moment.
Engine:
42dd 3" Turboback exhaust no cat no resonator
Custom downpipe
Turbosmart Plumb Back DV
Unitronic DV Relocate
Custom Intake
IE Intercooler
Cobb Accessport
Stratified Custom Tune
R8 Red top coil packs
VWR Motor Mounts
iAbed Billet RMS OEM RMS (Have the iAbed as a backup if this leaks)
iAbed Oil Sensor Adapter (Lets me run multiple oil sensors off the one OEM port)
Oil Temp/Pressure sensors
Unknown Brand Turbo Outlet Pipe Custom made by StayGold Performance
CTS Turbo Muffler Delete Removed with stock turbo
Fluidampr Crank Pulley
Latest Revision Vaico PCV 034 Motorsports catch can
RKX Tech PCV Diaphragm
DIY Battery relocate to trunk
A/C Delete (Removed lines, compressor, and condenser)
A/C Compressor Dummy Pulley
IE 83mm Pistons
Block bored to 83mm
IE Rifle Drilled Rods
ARP Head stud kit
iAbed Baffled Oil Pan
Garret G25-660 .72 AR
Tial MVS wastegate with dump tube (1 Bar spring pressure at the moment)
Custom Exhaust Manifold (StayGold Performance in Deep River, for any of you CT folks)
Rein Aluminum Waterpump
Aluminum Waterpump Union
Fueling
Torqbyte PM-4
Stratified Aux Fueling Kit
Nostrum Big Bore HPFP
MK7 Golf R Injectors
Custom LPFP Setup (Walbro 450LPH, Hydramat)
Suspension/Handling:
Brembo 18z Brake Kit 6 Piston Front 4 Piston Rearw/ MKV R32 Parking Brake Caliper Fuck a parking brake.
Stainless Steel Brake Lines
TTRS Master Cylinder
TyrolSport Master Cylinder Brace
TyrolSport Front Subframe Deadset Kit
TyrolSport Rear Subframe Deadset Kit
YCW Aeris Series Coilovers Ohlins Road and Track Coilovers
Ground Control Camber Plates
YCW Front Endlinks
H&R 26mm Front Swaybar (Soft Setting)
H&R 24mm Rear Swaybar (Firm Setting)
034 Motosport Adjustable Rear Endlinks
Powerflex Black Series ALK
Powerflex Black Series Front LCA Bushings
Passat Aluminum Control Arms
KMD Tuning Front Subframe Brace Removed for turbo oil drain fitment
ECS Tuning Rear Hatch Stress Bar
Transmission:
DieselGeek Sigma Six Short Shifter
42DD Solid Shifter Bracket Bushings
ECS Dogbone Mount
HPA 75a Red Puck
Delay Valve Deletes (Bleeder block and near Master Cylinder)
Stainless Steel Clutch Line
SouthBend Stage 2 Endurance (Rebuilt by southbend during engine rebuild)
Peloquin LSD
Steel Shift Forks with Brass Inserts 1-4
Exterior:
DeAutoKey LED Color Changing Foglights
Uro Tuning rear wiper delete
Osram Xenarc Black Edition Headlights
Depo Dark Cherry Tails w/ rear fog
Motegi Racing MR133 18x8.5et45 Rotiform Six 18x8.5et45
Firestone Firehawk Indy 500s 255/35/R18 Hankook V12 255/35/R18
Stud Conversion Removed to fit centercap for the new wheels
Gloss Black Rear Valance
Shadow Blue OEM Front Lip
Interior:
JL Audio 10w6v2-D4 Removed for performance
Alpine MWP-M500 Amp Removed for performance
Rear Seat Delete (No kit to replace it, might make one myself)
DeAutoKey Interior LED kit with red Footwells
Soundaktor Delete
Osir dual gauge pod with oil temp/pressure gauges
Pretty much the same as I bought it on the exterior besides the tails and slightly bigger exhaust tips.
As it sits now:
Engine:
Custom downpipe
Custom Intake
IE Intercooler
Cobb Accessport
VWR Motor Mounts
IE 83mm Pistons
Block bored to 83mm
ARP Head stud kit
Fueling
Torqbyte PM-4
YCW Front Endlinks
Transmission:
ECS Dogbone Mount
HPA 75a Red Puck
Peloquin LSD
Exterior:
Interior:
Soundaktor Delete
As it sits now:
