ugh... do you see the contradiction? Hence on average means the average driver...Who said anything about me? I purposely left all of that out of the equation and made it some person driving some car.
I'm trying to make it specific, you're trying to make it general. Your general argument is true, but that does not mean it applies to this specific situation. In general solids are more dense than liquids, that does not make solid ice more dense than liquid water. You have provided no reasoning to support the application of your general argument to the specific scenario.
Making it me personally in my personal car would just move the risk down even further, though, if you want to start swinging at that stuff. More capable car than average + more capable driver than average = fewer accidents than average...
Your original analysis was for 1 year, does one years worth of driving not require looking at more than one specific scenario?The point is to have a conclusion that is at least semi-applicable to real life.
The third alternative which I guess you are proposing as the safest is to go the speed of the people in the right lane - i.e. the speed of trucks. This means dropping down to 45 or less going up hills and picking up to 70 or more going down hills.
what am I ignoring?You are ignoring everything that doesn't support your idea and concluding that you are correct. You have 2 valid points. They are not sufficient for your conclusion - there is no way to say based on those 2 things alone that risk is increased at all, let alone how much it is increased.
Insurance mitigates the increased cost added by the increased severity - possibly mitigating it entirely. This has not been explored at all.
I'm not side-tepping a damn thing. YOU need to tell me:... and it still has not been shown that accident frequency is increased in this scenario. You continue to side-step this one at every turn and stick to your "driving at higher speeds, on average, across all drivers/all driving scenarios over the course of a year" argument and just assert that this scenario follows the average.
yeah, I thought about last night in a two hour commute... I noted that while "driving with traffic" people play leap frog and jockey for position when openings in the right occur and people are cutting others off and the people being cut off are braking and the people following them are braking even harder because they were traveling at too close a distance..etc. etc. Nothing safer about being in the fast lane driving with traffic.Why does it follow the average? You have hinted multiple times that it -might- not follow the average, then continued on assuming that it does. How do you support this?
Is the driving instructor right or wrong when he says that following the speed of traffic makes one less likely to be in an accident than driving at the speed limit? You previously agreed with him, now you are back to disagreeing. Pick one and support it.
1.) How does the fact that you may be driving with traffic give back your lost time to react from traveling at a higher speed?
2.) How does the fact that you may be driving with traffic give your back it's reduced braking ability from traveling at a higher speed?
A-holes on the road don't care what lane you are in or whether or not you are driving with traffic. Events due to a-holes are not reduced by driving with traffic, but severity in these events and the frequency of occurrence will increase due to my 2 points.The point was there are more factors than time to react and distance to brake. The general idea is that going the same speed as everyone else will result in fewer things happening that require a reaction at all, which mitigates the reduced ability to react at higher speeds.
What? How is going 65 in the slow lane not also going with traffic in that lane? I don't get it....I mean, going 65 in the slow lane (which btw I never see trucks going 45 in, but whatever... pass them and get back in slow in:iono gives you more time to react and better ability to handle if something like a tire shredding on said trucks than if you were 75 in fast lane.The first tested idea is that bigger speed differentials result in more accidents - that part has been proven and you ignore it.
What? Maybe driving the speed limit in the fast lane... but anywhere else? People encounter unexpected things no matter what. If you don't expect to go out for a drive and encounter someone driving the speed limit, then I just don't know what to say. This is silly. You are reaching a bit on this. This argument does not imply lower risk at all by driving faster.A second untested idea is that people expect other people to drive at the same speed as most people. Accidents happen when people encounter unexpected things. Driving at the speed limit is an unexpected behavior and increases the chances of someone hitting you. You ignore this.
Attentive driving does not impact my statements at all. Unattentive driving and the FACT that unattentive drivers exist in ALL lanes of traffic only bolsters my two points.A third untested idea is that driving at the speed of traffic requires a driver to pay more attention to traffic than just setting cruise control at the speed limit and turning on Rush Limbaugh while combing his mohawk. A more attentive driver is less likely to be in an accident. You ignore this.
Just as many reasons why risk is increased with speed. You seem to assume that people just jump in line and drive. Not in my commute.There are many reasons why one might be less likely to be in an accident by going the same (changing) speed as everyone else instead of cruising at the speed limit regardless of surroundings, all of which contribute to risk.
I also think your traffic is worse than mine, making your thoughts different. I can travel the entire way to and from work with cruise control set at 75 indicated (more like 70 actual) without touching the brake more than maybe 3 times. That's what I call moderate traffic because I still have to change lanes frequently to pass or be passed and that's what I have in mind here.
Yeah but what if a deer jumps out in front of you on the interstate?
I don't think it's reaching to assume that no one drives the speed limit on the interstate. When I park the cruise control on the speed limit I get passed by EVERYONE including trucks if it's not an uphill section. It makes me extremely uncomfortable and nervous. It does not feel safe at all to me. Do you not get this same feeling? Try it sometime, drive for at least an hour on the interstate without exceeding the speed limit at all, not even to pass people, and see how safe you feel compared to driving like a normal person.
People passing trucks or getting annoyed with trucks trying to pass each other while going uphill are 95% of the dangerous situations I see out here, and the 45mph truck is something I see roughly 2-4 times per day.
I mean stay at or below the limit the entire time no matter what - that makes me uncomfortable. Traffic stacking up behind me while I take 2 miles to pass someone does not feel safe, but that must be just me. I worry more about things happening behind me than in front of me.
Do you live in bizarro world where people actually treat the limits as limits and not the absolute minimum speed?
