I installed the stage 2 tune tonight. Not as much of a differnce from Cobb stage 2 as I was hoping. 3rd gear is a little more fun now at least.
Also mt catted downpipe really muffles the cackle tune. I did expect that but still gave it a go for the $10
Flash tune or protune? Stock catback?
I had this same experience as wellDid you get the low torque or high torque tune? This is going to be a big thing as far as if you felt a difference or not. The difference in my stage 2 high torque tune vs stage 2 Cobb OTS tune was more dramatic than my stock car vs Cobb OTS stage 2. The torque was astronomical. Completely different powerband. It hit like a freight train vs the Cobb OTS map feels linear, tame, and boring.
How long will our K03's last with the Stratified Stage 1 tune? 20ish PSI seems a lot...
I'v been considering switching from APR to stratified recently and I'm curious does anyone have a beluga catback with this tune? I also have the catback paired with an APR downpipe but I'm replacing the midpipe section that has the CAT with a section of straight pipe to make it catless. I'm just curious if anyone has a similar setup, I want to make sure I can get some good crackles out of this tune if I'm going to spend a ton of money making the switch.
Also does anyone know how much different peak numbers are between the two tunes? I definitely love the amount of power I'm getting out of the apr 2.4 tune but I feel like it could be smoother.
can you record the rattle?Any recommendations on using this tune on a higher mileage gti? I'm at 113k miles but I've replaced the PCV, Water pump, Chain tensioner, timing chain, clutches and mechatronic unit. Currently have a rattle on cold start and accelerating directly after turning the car on so if anyone has info on that, that'd be nice.
Aftermarket mods:
APR Carbonio Intake
CTS Turbo Turboback 3" Catted
FK Coilovers
