Sauce118
Your vacuum seems rather high, you should be between 18-20Hg. Check for vacuum leaks.
+1 thats what i was gonna say!
Well, update. It wasn't a vacuum leak. I had to adapt the throttle body. I didn't use vagcom. Old method, which most will disagree but it worked:
1. Open drivers door.
2. Open hood.
3. Put key in ignition.
4. Turn to ACC.
5. Leave for 3 minutes.
6. Close hood.
7. Turn it over.
8. Enjoy your car starting on the first crank again.
Sent from my LG-H910 using Tapatalk
Could you explain this. If there is a vacuum leak, why would he have more vacuum? Wouldn't it be closer to 0+1 thats what i was gonna say!
Yeah im dsg, it feels like since the adaptation fails, the TB is either shut or wide open. At low speeds the car bucks, and acceleration is choppy, 0-35 mph is hell. I also can hear the car bleeding off the excess boost. Cars also running rich to compensate.
For perspective my mod list (eventually gonna make a thread after i'm tuned and this crap is sorted out):
Cobb Tuning AP3-VLK-001
Cobb Tuning Downpipe Non-Resonated
Cobb Tuning Catback
Integrated Engineering Cold Air Intake
Integrated Engineering Intake Manifold
Spulen Turbo Muffler Delete and Boost Pipes
Fluidampr + ARP Bolt Kit (Crank Pulley)
ARM Motorsports FMIC + Stock IC Delete
Grams 70mm Throttle Body
R8 Coilpacks
NGK BKR7EIX (2667) Spark Plugs Set (4)
Gruven Billet Pulley Set (Alternator and Tension)
Port and Polished Stock Turbo (IHI RHF5)
Forge Wastegate Actuator
GFB DV+
PTP Lava Wrap on Downpipe
PTP Turbo Blanket
Currently running Cobb Stage 2 Stock MAF 93 oct.
Attempted to run the first revision of my stratified map, but anything above ~30-40mph causes overboost and limp mode.
I know someone who ran the TB with I.E manifold and they have 0 issues. And yes I realize in this setup the turbo is now the restriction.
I am having preciously this same issue. Running my stratified base map on my new KO4/IE intake manifold setup and my car is doing the exact same thing. Going to get logs for Alex today to see if he can fix it or if it's just a defective TB.
Yup it was indeed the grams 70mm throttle body. Swapped back to the stock TB and the car runs 100% now. Going to send back to grams for a refund.
No offense meant to those of you who have gone this route, but since big turbo cars make big power on stock TB and intake manifold, I simply don't understand why anyone would change either of those items out. Seems like the experience is a nice looking engine bay but nothing but problems for vanishingly small gains or a potential misappropriation of the benefit to the upgraded throttle body, when potentially the same responsiveness could be regained with a new OEM-spec throttle body.
Because we’re always pushing to find more power
Exactly... Plus it's my car lol
Oh for sure, no disrespect meant. I just like to try to understand people's thought processes.
