BudgetPhoenix
Thanks for the reply, I think I found the info online you were talking about. This baffles me because I also have Elsawin on my PC and it doesnt mention this anywhere
boy that looked like fun! lol! kudos to you for going through that in your driveway
ps where did you find the soundaktor in your car? under drivers side cowl? i couldn't find mine, which makes me wonder if the previous owner took it out already haha
I've been strongly considering ditching APR and picking up a used Cobb Accessport to pair with a Stratified Tune...
Following. Will be interesting to hear your thoughts if you do decide to go through with it.
I often wonder if doing this with the K04 would make a difference or not, especially since I believe APR V3.1 is rather aggressive already.
Good to hear from you again!
It's a pretty steep upfront cost (Accessport + Stratified tune) but everyone seems to love the Stratified tunes, especially if coming from APR stage 2.
However, a few things I've read indicate that the APR K04 file is pretty stout. I don't know if there's a lot to gain by switching to Stratified from the APR K04 file.
DIY RSR Clutch is installed! Also replaced the rear main crankshaft seal with the iAbed Billet RMS. Parts lists, resources, and install tips below. Full Flickr album here, select embedded photos below. My Overall Impressions are at the bottom of the post. I will update them after clutch break in.
__________________________________________________
Clutch
Parts List:
Pressure Plate (07K 141 015 BX) - $365.26 + Free shipping (AudiUSAParts.com)
Clutch Disk (1878 005 146) - $110.99 + Free shipping (eEuroparts.com)
Dual Mass Flywheel (06J 105 266 H) - $75 + Free shipping (forum member, used for 50k on a stock Jetta)
Throwout Bearing (0A5 141 671 F) - $108.35 + Free shipping (ECStuning.com)
Transmission Fluid (G 052 527 A2) - $41.11 x3 + Free shipping (ECStuning.com)
VW Clutch Alignment Tool (T10097) - $15.99 + Free shipping (ECStuning.com)
Flywheel bolts (N 906 650 01) - $2.02 x8 + Free shipping (ECStuning.com)
Pressure plate bolts (N 903 207 01) - $0.99 x6 + Free shipping (ECStuning.com)
Throwout bearing bolts (N 908 470 02) - $1.00 x3 + Free shipping (ECStuning.com)
Total: $824.02
Resources:
Calkulin's "Build your own RSR clutch kit" Thread
T is for TURBO's Clutch Replacement Thread
GTI Mod Blog's Clutch Replacement Video
Install Tips:
Overall it wasn't a terrible job but I had a few issues. My goal was to remove the least amount of components possible. I didn't want to drop the subframe or remove the axles. I ended up unbolting both axles at the differential flanges, removing both flanges at the differential, and unbolting the ball joint at the control arm on the driver's side. This allowed enough clearance to move the driver's side axle over into the wheel well (you can see it in a few of the pictures). I also removed the bracket that holds the transmission mount to the transmission. Lastly, I unscrewed the 2 throttle body screws and a disconnected a few electrical connections between the radiator and front of the engine. All of this gave me enough clearance to get the transmission out but it was quite a pain. I didn't really have any other issues besides things generally being difficult to maneuver. I did notice a ~1/2" hole that was open but looks like it should have some kind of plug on the bottom of the transmission. I plugged it from the outside with a simple, ribbed panel fastener from the hardware store. A few notes:
- When I finally got the transmission off, the bell housing was full of sludgy, gritty crap. Not sure if I had a leaky throwout bearing or what. Took me quite awhile in the parts washer to clean it out but it came out nice.
- I purchased a used OEM DMFW to replace mine and I'm glad I did. My flywheel was pretty bad looking. I bought Harbor Freight version of 2" Scotch Brite pads and arbor and hit the flywheel surface with the medium grit "scotch brite." It worked great and cleaned the flywheel surface right up. I don't anticipate any problems in the future but only time will tell. The flywheel was a pain to bolt onto the crankshaft. It seemed to only line up one way and there are 8 bolts so 8 possible way to align it.
- To keep the crank/flywheel from turning when I torqued the 8 flywheel bolts I put a 24mm socket and breaker bar on the crank pulley bolt. There is an OEM flywheel retainer tool if you are interested (tool number 3067) that runs about $25.
- I got the rest of the clutch together without issue. Had to open up the 3 guide holes on the pressure plate with a ~1/4" drill bit as is well documented.
- The differential flanges are spring loaded but went on easily with 2 people: 1 used a prybar to press the flange in, the other used a ratchet to install the bolt that holds it together.
- I didn't bench bleed the throwout bearing and it took a ton of fluid (2ish pints) to bleed conventionally but it got there eventually.
Rear Main Seal
Parts List:
iAbed RMS & VW T20097 (462-103-171F-KT) - $124.00 + 16.56 shipping (excelerateperformance.com)
Victor Reinz Sealant (703141410) - $7.21 + Free shipping (ECStuning.com)
Total: $147.77
Resources:
VW Service Manual - RMS Installation Procedure
A big thanks to Greg from Excelerate Performance for answering all the questions I pestered him with about the RMS installation. He was so helpful and quick to respond.
Install Tips:
I didn't realize that it would be necessary to press the spring loaded seal into the billet bracket. Luckily I have a hydraulic press and found a PVC coupler that was a close enough diameter to work as a seal driver. It certainly wasn't ideal and took some time but I got it *almost* fully seated. I didn't want to press anymore for fear of deforming the seal. Installing the seal over the crankshaft was simple following Greg from Excelerate Performance's instructions (above) in addition to the service manual. I purchased the sealant he recommended as well as the install tool T20097. If I was forced to do the job without the tool I think I could have found a wax paper cup or similar of the correct diameter but it was cheap enough and worth it to make the job simple. Don't forget to put the "intermediate plate" heat shield/gasket thing back on before you bolt up your flywheel!
Overall Impressions & Test Drive
Firstly, I've been having some symptoms that led me to complete this clutch job. I've experienced clutch slipping intermittently at low RPM, high gear scenarios since the spring. The OEM clutch had 91k miles, the last 25k of which have been APR Stage 1. I took it easy on the clutch to the present 106k. The clutch had also gotten grabby and I had a lot of chatter. Gear changes were somewhat rough no matter how well timed my shifts were, especially in lower gears. I had also been experiencing really notchy shifting, to the point that I didn't feel comfortable forcing the car into 1st gear, during this recent cold weather. Lastly, I began experiencing intermittent throwout bearing squeal on engagement, particularly when the car was cold.
During assembly I completely replaced my transmission oil with OEM fluid and re-aligned my Dieselgeek Short Shifter. There seems to be some confusion as to which OEM fluid should be used on ECStuning.com but I was assured by one of their tech's that the fluid I purchased will work fine. I was surprised when I poured it out that it was close to the consistency of motor oil - much thinner than the 75w90 Motul Gear 300 oil I used before. I fired up the car and, immediately upon putting it in gear, the transmission felt great. That new fluid and short shifter alignment did the trick. The clutch pedal feels great, approximately 25% stiffer. The biggest difference is that clutch engagement is back to being buttery smooth. No chatter or grabby feeling. I'll have to get used to driving with the new clutch feel but I'm confident that will only take a few days. I'm excited to get through the break-in period because it feels like it will grab really well and be a blast to drive. I removed my clutch stop as a precaution but the bite is far enough off the floor that I think it will be fine to use.
Overall the drivetrain feels brand new and I couldn't be happier. I'll update this section after clutch break in.
Awesome man! I am glad that flywheel worked great for you! I love my RSR clutch as well! I just added a dual caliper rear brake on my car and have the some build log pics.
Thanks again for the flywheel! So far I'm enjoying the clutch. Just starting to ease in to putting some power through it.
Just checked out your build log updates - the front TTRS brakes look awesome. Very nicely done. Dual caliper setup on the back looks awesome too but I have to ask, why did you decide to do it? If for no reason other than because you can, that's cool too! Any issues with pedal feel running front & rear brakes that big?
I came across the touareg/Cayenne calipers for 50 bucks a piece and I had gotten the mk7 rear perf calipers for a really good price, so the "I did it because I can" and I am running out of mods to do.... HA!
I run the TTRS master cylinder, so it feels great and stopping power is great too!
I think I may jump in the AWD retrofit boat sometime this year, I think....Next best thing after doing that LSD install when I changed the clutch
I always enjoy reading folks build threads. I think its amazing how people tackle these cars themselves.
The Timing Chain/Tensioner replacement and Rear seal/Clutch replacement is no easy task. Good Job Tackling that yourself :clap::clap::clap:
I like messing around with cars have since I had my first car many years ago. For some reason though this GTI scares me. I unfortunately injured my back at work a while ago which limits allot of what I can do now, but even if my back was in good shape, I would be hesitant to do what your doing.
My cars I have had prior to the GTI were much easier to work on. Less plastic bits and less mess under the hood.
So again Bravo for tackling all this yourself, I sub'd to keep track of your progress. :clap::clap::clap::thumbsup:
Jeff
