I've searched on here and google. I cant find the answer to this dumb question:
to remove the center caps do I have to take off the wheel? If not, how do I remove them? :mad0259:
Yes, you have to take the wheel off. From the inside of the wheel, I used a flat head screwdriver and carefully them (lifted the clip...).
No need to take the wheel off the car... just use a small flathead screwdriver and pry the centercap out. Take care not to scratch the wheel when doing this.:w00t:
Take it off, use two fingers, insert them into the hole until it comes out.
I guess it might be possible when the wheel is on.. I took my wheels off and it seemed like the "right" way to take them out...[/QUOTE
It all boils down to whether you want to risk scraping your wheels. If you feel lazy do two a day...off swap on, repeat as necessarily :thumbsup:
Wait.
Excuse my resurrecting of a dead thread...
But are the centercaps pretty easy to remove? Or should I just buy new ones to put on my new wheels?
Since you have new wheels you will already have your old ones off. Caps are stupid simple to remove. Just push from behind the cap with two fingers like the guy stated a few posts above. It'll just pop out.
