Sorry, to clarify the limp mode issues went away after the first revision. However, there is still some driveability issues that I was told are difficult to tune out as they can't really be captured/felt on the logs.
Coming back from auto parts store to get a missing torx 30 bit to install the new PCV and see if it fixes the issue...
...I got rear ended.
FML
All people involved okay. Trunk is slammed shut...also the exhaust changed its sound a little...gotta take it and see what needs to be done. 2000 Xterra wasn't paying attention and just rammed me. I was stopped waiting to merge. Some people...he had 2 kids in the car too!!
FML
That was 100% of it. PCV valve failures have very non-specific driveability symptoms, it can be pretty infuriating.
Maybe 90% of it. A day after the work was done I'm seeing:
P0101 Mass of volumetric Air flow Circ. Range/Performance.
P2177 System too lean off idle, Bank 1
Someone mentioned that their PCV return routing was the problem. I'm going to reach out to COBB one more time before returning their intake and trying another one.
I know it's a long shot and I apologize if you already did this. Make sure stratified is tuning in for the correct maf sensor. I have the stock maf and my first couple revisions were tuned for Cobb's larger maf and it caused some problems. Doesn't hurt to have them verify.
If the aren't tuning for the extra 1/2 inch or so of flow you'd definitely run lean.
In addition, have you cleaned your MAF lately?
Boys, just bought a cobb accessport for the low. Next up is buying this stratified protune and goes in the k04. [emoji275]
and then?
Probably leave it alone for a long time ??*
