Jimbosantos96
Hey guys, I’m hoping you can help me out with a little problem going on in my car.
So sometimes, I’d notice that when I put it on drive, it would of just rev. The white letter indicating he gear would start blinking on the dashboard too. Also Sometimes, this happens when I put it on reverse too, it just stays stationary and I have to turn the car off and back on to make it work again.
It showed P0783 (3-4 shift) at the time and I thought maybe I need to add more transmission fluid, so I did and it helped out. It stopped with the blinking white letter and staying stationary, for a month or so. Recently, it started doing it again. The problem is, the shutting it off and turning back on to make it work isn’t fixing the problem.
I checked for codes and all of a sudden it showed 4 more codes, and the previous one.
P0747 (pressure control solenoid a stuck on)
P0871 (1-2 shift)
P2096 (post catalyst fuel trim system bank 1 too lean)
P2196 (O2 sensor signal stuck rich bank 1 sensor 1)
I’m gonna try to take it to the shop tomorrow if they have space for me but what do you guys recommend me do? any of you experienced with these problems?
P0871 (1-2 shift)
