grambles423
Automotive Engineer
Hey Z. I've got this VWR filter lying around taking up space. You want?
Yeah. Unless there's a dry option?
how come you are taking off the caliper bushings?
the VWR is dry i believe.. i highly recommend the aFe that i run. its dry. i recently cleaned it after about 7500 miles of use on and off.. was pretty dirty. soap, water, air dry, done.. no oil, no nothing..
but you can't argue with free... the VWR is pretty expensive for a drop-in too.. isn't that the one you ran during your intake tests/logs?
Bushings are off. Nvh went down pretty substantially. Mostly road noise and the sharp thunks that made that knocking noise up front. It's given that that all went away seeing as thought its rubber and not metal.
However, a lot of pedal feel went away. With the Stoptech pads its still a substantial upgrade, but there is an introduced numbness now in the pedal. ill write this off seeing as though there is end in sight for my vehicle, but I highly suggest this mod for anyone.
haven't fully followed - what car you plan on getting after this one? you came to mind the other day as i was driving next to a new honda accord sport on the freeway.. honda did a superb job w/the redesign, at least with the sport model anyway.. thing looks like an A4 from certain angles.. i would drive that car, and i swore to never return to hondas.. i mean, in all reality, i probably never will, but that is a nice ride. i bet the 6 speed in it is ridiculously good.. too bad youd have to special order it..
