bigturbonyc
People are getting stupid money for the tdi buybacks...can't wait til we start get some fixes rolling in, it's effing slow and ineedmoney
I just kept going until it fit right. Don't trim where it attaches to the TOP, but trim where it attaches to the compressor housing, and both DV connections. I took probably an inch off each of those. Then push it up onto the compressor housing as far as you can while you tighten the clamp.
Only part that sucks is the DV is pretty much wedged in there. I actually just ordered some parts to block both ports for the DV on those hoses and move my Synapse valve up to the throttle body pipe to get it out of there.
Thanks, trimmed about 3/4 to 1" off on Sunday. Seemed to be good, will check again today or tomorrow.
Not sure why people take the front end off to remove the motor. It's much easier to remove it straight out the bottom.
On jack stands? Or a lift? HahaNot sure why people take the front end off to remove the motor. It's much easier to remove it straight out the bottom.
Sent from my Pixel XL using Tapatalk
On a lift out the bottom. On jackstands out the top. You need to take the trans out to take it out the top, but you would eventually need to anyway. Removing the front end just seems like an ass ton of extra work.
It seems to be a theme for VW people to remove the front end. I've removed a LOT of VW motors and never removed a front end. But I guess whatever is easier for the person doing the work :thumbsup:
i was going to say pull the front as well. remove bumper and a few bolts to the support it just swings out of the way. it's a lot easier to remove/reinstall the sensor wiring that way too.
