Halvie how much boost do you run?
21psi for 490whp
bumped it up a bit. now around 29psi for 675whp.
Don't have a real answer actually. Haven't bothered to put in the analog sensor for my p3 gauge. Gauge says 18.5ish. Vagcom does hit 2550. What does that equate to again?
21psi for 490whp
1. ForceFed Engineering Big Turbo kit - $3500 - Deposit Made
i don't think the new apr kits are advertised to hit 400 to the wheels. maybe with fueling.
Also, is this bad?
Not enoughWhat does that equate to again?
At least you found it
Direct port meth with a bunch of boost and timing you'd probably be around there. You'd need to buy a failsafe though.Thanks for the note. If I can be ballpark ill be happy. I am not the only one getting this setup the others to my knowledge will be setup with internals and fueling, so i will have some comparison points. And if I don't make 400 and become unhappy with the performance I will just get a bigger turbo :thumbsup: gotta start somewhere.
