I think Arin and Tom are trying to imply that your oil pressure could hover around 30psi in a high speed turn, but I don't see that being the case.
I think you’re confusing me with someone else. I haven’t implied anything; just shared experiences and data we have.
In regards to pressure, the data I have shared is of a continuous lap around Mid-Ohio with our MK6 GTI and GLI racecars. The Y-axis is oil pressure and the x-axis is second, which also represents roughly 1 lap around the entire track. With the OPS system turned off (which, was via a manual switch when first implemented on the race car, and was mounted in the passenger seat area too) pressure dropped as low as 8 PSI. This is well below the acceptable range under load and ultimately resulted in an engine failure.
The reason the OPS was not activated was because the driver forgot to turn it on. This happened quite a bit, which is why we new it needed to be automated.
they'll keep trying to pitch their system but it works without the controller on every other car i've seen.
Without the controller, the driver has to manually flip on a switch to activate the system. As we mentioned before, the drivers did not always remember to do this, even though they are professionals, so we felt our customers would need something automatic as well.
If you simply have the system activated every time there’s power (so no controller), it will dump 2 quarts of oil into the system at idle, or when the key is turned on and the engines is off. This is because even with the system operating off of low oil pressure (below the recommended operating condition of ~30 PSI), at idle, and with the engine off, key on, the system would be active as pressure would be below this point. The extra 2 quarts, or roughly 40% more oil would overfill the system. Overfilling can be hazardous for the engine’s health.
The can controller handles enabling the system under the correct operating conditions. This prevents overfilling, turning on when it shouldn’t, and makes the system hands free.
most of the racecar builds i've found run it more as a safety than anything, and that's what it does. save you in a pinch. it's not designed to be a source of constant oil. that's what the baffling (or lack therof) in the pan is for. if anything, adding another `1/2 qt of oil will help more than a controller. so it will be activated less often.
Baffling doesn’t fix the issue. The issue is the oil cannot return to the oil pan quick enough during high G sweeping turns. No amount of baffling or responsible overfilling helped, or rather, prevented engine failure. No swinging oil pickup arms, no widening of oil return passages, etc. We tried many different things. The OPS was the only solution that worked.
Last thoughts:
I do prefer you to purchase the APR system. However, I’m more concerned customers know of the issue so they don’t blow their engine on the track. If that means some will try to do it on their own, their way, then that’s fine by me. It’s a rather complicated system to do on your own, especially if want it to mount nicely in the engine bay, and operate in the manner in which we’ve specified with the controller. It’s not a simple walk in the park. If you don’t want to take that walk, we have a solution. :w00t:
