Hedgehodge
https://1drv.ms/v/s!Am4oxjiBayafkNcC4uGBWVvUytko6w
Edit: I unplugged the clutch delay valve here attached to the clutch master and no brake fluid here either coming out https://1drv.ms/u/s!Am4oxjiBayafkNcDB5w0H8b9BVe48g
https://1drv.ms/v/s!Am4oxjiBayafkNcEjJnxXy7tPjxQqg if there was air when I pressed the clutch 5x I would have seen it move some...nothing. I bench bleed this master and as I did it would push fluid, then pull it back with clutch going in then pulling out...
https://1drv.ms/v/s!Am4oxjiBayafkNcGFH4ZKvV2FUQxng
Tons of fluid going into the hose straight out of side of brake reservoir, poured out...how do I bleed this clutch master , did it on bench fine
So I intermittently had this issue in the video so I decided to replace my clutch since I assumed it was the slave cylinder.
I replaced my clutch, pressure plate, flywheel, clutch master cylinder, slave cylinder/throwout.
I bench bleed the slave and clutch master, I even went and added fluid to the lines and quickly connected them (straw affect).
I tried manual bleeding and motive pressure bleeder at up to 15psi, scared to go past that, don't want to blow seals in brake master.
I filled the brake reservoir to the tip top.
What gives , please help
