super steve
Here is my short and brief guide on how to change out the bulbs.
You can pull the light boxes out, without the use of a screw driver.
The lights have an indentation on the right side (both driver and passenger side lights have the indentation on your right when facing them from the seats) You can put your finger nail in the indentation and pull it down and they fall out. you have to push in the sides of the connector to disconnect the light box. You have to use some force to get the box out, but disconnecting the light box plug is VERY easy to do.
All you gotta do after you get the metal box out is remove to metal part held by 4 tabs. you will see what i mean when you take it out and its very easy with a flat screw driver
Metal Box
picture showing the tabs
What the box looks like with out the cover
Install the bulb
Then connect the connector and snap it back in place
Final view of the footwell
Sorry about the bad iphone picture quality
Metal Box
Install the bulb
