Dude's R Build
McQueen77
Banned
2013R
That a Unitronic? If so, and its like the GTI method, I have mentioned this issue many times. The Uni has no isolators. It is hard mounted at all points. Engine moves, intake cannot. Things crack. Bad design.
Funny you mention the intake... Looking in there I noticed that it cracked near the welds for the screw that attaches to the engine.
thedude4bides
Yes it is. Uni warrantied it and the replacement had the pylon reinforced like 3 times as much. They also explained that over/under torque-ing can exacerbate the cracking issue. Should 7 ft/lbs. No more. No less. I am pretty sure it was way over-torque-ed when it was installed. I'm not defending the design but I do feel this is the best intake for the R.
In other news, my rear-diff coupling/guibo/harmonic balancer/whatever-you-want-to-call-it has been replaced under warranty. I just owe the $100 deductible that my "platinum" coverage has.
Next week I'll get the new white-line end-links installed and have my sway bushings greased.
thedude4bides
Yikes!
Address 01: Engine (CRZ) Labels: 06F-907-115-CDL.clb
Part No SW: 5K0 907 115 M HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0030
Revision: 5BH20--- Serial number:
Coding: 0403010A180F0160
Shop #: WSC 66565 257 00032
VCID: 3467F90857E32F81BB3-8061
5 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 002 - - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 114282 km
Time Indication: 0
Date: 2015.01.30
Time: 18:59:49
Freeze Frame:
RPM: 2476 /min
Load: 16.9 %
Speed: 97.0 km/h
Temperature: 84.0°C
Temperature: -5.0°C
Absolute Pres.: 960.0 mbar
Voltage: 14.224 V
000769 - Cylinder 1
P0301 - 002 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 114282 km
Time Indication: 0
Date: 2015.01.30
Time: 18:59:56
Freeze Frame:
RPM: 2575 /min
Load: 11.4 %
Speed: 100.0 km/h
Temperature: 84.0°C
Temperature: -6.0°C
Voltage: 14.224 V
000771 - Cylinder 3
P0303 - 002 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 114282 km
Time Indication: 0
Date: 2015.01.30
Time: 18:59:56
Freeze Frame:
RPM: 2575 /min
Load: 11.4 %
Speed: 100.0 km/h
Temperature: 84.0°C
Temperature: -6.0°C
Voltage: 14.224 V
000772 - Cylinder 4
P0304 - 002 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 114282 km
Time Indication: 0
Date: 2015.01.30
Time: 18:59:56
Freeze Frame:
RPM: 2575 /min
Load: 11.4 %
Speed: 100.0 km/h
Temperature: 84.0°C
Temperature: -6.0°C
Voltage: 14.224 V
000770 - Cylinder 2
P0302 - 002 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 114282 km
Time Indication: 0
Date: 2015.01.30
Time: 18:59:56
Freeze Frame:
RPM: 2575 /min
Load: 11.4 %
Speed: 100.0 km/h
Temperature: 84.0°C
Temperature: -6.0°C
Voltage: 14.224 V
Readiness: 0000 0001
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 144B800C492B80FA280E01E692200141B70000
Shop #: WSC 01357 011 00200
VCID: 7BF51234FA3D20F93A9-802E
4 Faults Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 130
Mileage: 114207 km
Time Indication: 0
Date: 2015.01.30
Time: 07:56:22
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 57
Count: 50945
Count: 1
Count: 769
Count: 0
03840 - RPM Sensor Front Right: Incorrect Signal
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 131
Mileage: 114347 km
Time Indication: 0
Date: 2015.01.30
Time: 19:54:00
Freeze Frame:
Count: 16384
Count: 0
Count: 12800
Count: 55
Count: 51458
Count: 256
Count: 767
Count: 11520
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 5
Reset counter: 138
Mileage: 112954 km
Time Indication: 0
Date: 2015.01.18
Time: 18:28:30
Freeze Frame:
Count: 16384
Count: 1026
Count: 12800
Count: 56
Count: 50944
Count: 0
Count: 512
Count: 4096
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 138
Mileage: 112954 km
Time Indication: 0
Date: 2015.01.18
Time: 18:28:40
Freeze Frame:
Count: 16387
Count: 4
Count: 12800
Count: 16390
Count: 51456
Count: 0
Count: 769
Count: 4352
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA1RPAL
Coding: 00003131
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360_SK35.rod
VCID: 3F8DA624A6A5FCD9561-806A
Seat occupied recognition:
Subsystem 1 - Part No SW: 5K0 959 339 B HW: 5K0 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--000034HW00
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME7D52346CZZZ2
Crash sensor for side airbag; front passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME5647346CZZZ+
Crash sensor for side airbag; rear; driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME402C6C71ZZZZ
Crash sensor for side airbag; rear; passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME7A156D0CZZZ3
Crash sensor for front airbag; driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME2128632BZZZB
Crash sensor for front airbag; front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME7E1F632BZZZ-
1 Fault Found:
9483008 - Seat Occupied Recognition
B10B3 00 [008] - Function Restriction due to Implausible Message(s)
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 8
Reset counter: 137
Mileage: 112954 km
Date: 2015.01.18
Time: 18:28:46
Address 22: AWD Labels: Redir Fail!
Part No SW: 0BR 907 554 C HW: 0BR 907 554 C
Component: Haldex 4Motion 3018
Coding: 0000005
Shop #: WSC 00000 000 00000
VCID: 4581B4CC0C79A6091CD-8010
1 Fault Found:
00625 - Vehicle Speed Signal
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 2
Mileage: 114171 km
Time Indication: 0
Date: 2015.01.30
Time: 07:30:24
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 251 3305
Revision: 00H22000
VCID: 377DCE044695C4999E1-8062
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 8
Reset counter: 137
Mileage: 114601 km
Time Indication: 0
Date: 2015.02.02
Time: 09:40:52
Freeze Frame:
Voltage: 14.13 V
DU
Temperature: 10.0°C
RPM: 979 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
2013R
I'm thinking the ECS, TPMS, Airbag, and steering wheel may be related to a bad ground as was suggested to me by another R owner on Vortex. The misfires may be due to carbon buildup but time will tell.
i'd check with the humble mechanic on youtube. hop into one of his videos and make a comment asking about it. He works on VW's every day.
or just contact him maybe for better luck in a response.
http://humblemechanic.com/aboutme/contact-me/
thedude4bides
Updates:
Turns out the weird electrical issues were from the faulty wheel speed sensor. Had it replaced and all is well.
Had whiteline Endlinks installed when I had CB Tuning "attempt" to grease the bushings on my VWR sways. Yes, "attempt" is what they put on my bill because apparently they were unable to grease the fronts because VWR makes it impossible to service without cutting off the bushing housings. I've emailed VWR about this and their solution involved having CB Tuning hack up the original parts and replaced with VW OEM parts with some Jerry rigging involved. Not thrilled at that prospect. Reason for all this is the sways are squeeking like crazy going over bumps.
Lastly, I've looked into getting out of the R due to high mileage and the prospect of having a 100k mile car out of warranty while continuing $600/mo payments. I'm still underwater and there is no other car that fits my needs better so I'm doubling down on it and adding more parts to the mod list:
-NEUSPEED charge/discharge pipes
-CTS intake heat shield (the one behind the engine)
2013R
dood.. that sounds like a plac decision... you are just hunting for unneccessary things to spend money on now..
maxtdi
Why add mods... sigh.
