Francoleon91
?Knobfeel mod, achievement unlocked
Nice, did you get the brakes as a kit or source the parts individually?
Well shit. That's rough. Plans?On another note. While we had the car up on the lift for the brake install. We went to go install an 034 dogbone support insert and realized that the aluminum dogbone piece i already had in there was broken lol and also my trans case is cracked.. SMH..
On the plus side, brakes look ?
Dammmmn franco
New wheels look sick. i think those rotiforms are overrated and over played.
You should still do a regular oil change every 2 changes or something like that just to be safe.
There's really been no evidence to support that an extractor does a poorer job than a normal pan drain. If the oil is warm then any containments will be in suspension. Whether it comes out through vacuum or gravity doesn't matter.
Love the new wheels too. PS4S's are definitely a top notch tire. Not sure if you had an alignment done but zeroing out the toe can help with wheel spin...obviously a LSD will help too
