So i asked GFB if they would do a group buy and this was what i was told
"Hi Aubrey,
Sorry but we cannot offer group buys. We only sell at RRP as a service as we cannot undercut our distributors/dealers. We are releasing a Golf R specific valve in about two weeks for the reasons as below;
We have been busy here at GFB addressing the issue of a small handful of customers who appear to be having some issues with our new DV+ leaking in their vehicles specifically the Golf R. This has apparently only been an issue with VAG vehicles fitted with the remote mounted factory diverter valve, where they have been experiencing a fluttering/ leaking sound under load at mid RPM since the fitment of their DV+. As it is a concern for any of our GFB products to have issues, we have promptly looked further into this.
The DV+ was primarily designed for direct fitment to VAG vehicles which had the factory diverter valve mounted directly on the turbocharger compressor cover. However since the pre-release of this product, we have also found direct fitment to vehicles with the remote mounted diverter valve using the same part. This fitment has never until now been an issue for us, since the vehicles which we have tested them on have been fairly standard/mildly modified VW Golf R’s.
It appears that the factory remote diverter valve mounting block runs a larger diameter inlet bore than the turbocharger compressor mounted models. This is a concern as it actually plays a huge part in the valve area ratio of the forces acting on the DV+ piston. Although it is not a problem on all of these vehicles, this is still not acceptable. We have seen factory mounting block diameters ranging anywhere from 18.8mm to 19.7mm, so there clearly is a tolerance issue on the factory part which we must work with. Essentially, what is happening in the practice is these remote mounted units are only just partially trying to open the DV+ piston due to the incorrect piston/face area ratio. This is only with higher than stock boost levels. Still not acceptable.
Our solution: We have nearly completed an almost identical design DV+, but using a larger piston diameter. This will completely eliminate any issues, and ensure 100% fitment on every vehicle remote mounted diverter valve. These New DV+ replacements are approximately two weeks from being available. The current DV+ will continue production unchanged for all VAG vehicles fitted with direct turbocharger mounted diverter valves."
Cheers,
Gunda Adrian
