1. So to that mindset, if UNI logs are showing no timing pull, they could be running their tune more aggressively?
2. That's a fair comment, but the logs are regularly showing timing pull with APR V2 in the range of 2-5 degrees. Are you saying this is normal for the tune?
Timing isn't simple on these cars, largely in part to the complex ECU.
I assure you, there is much more than 1 timing map, there is also many maps to regulate how timing is compensated for, how it is pulled, the sensitivity of the knock recognition and even how quickly it is added back after it was pulled. Heck, there is a max referenced load request 2d map that is used under knock recognition that sets a cap on multiple 3d maps used when the ECU senses the driver is requesting torque and another that is used with no knock recognition. For every component that makes power, there is a secondary map to be referenced if the ECU recognizes a knock event.
The philosophy of every tuner is different, it isn't a simple answer to determine one tuner is more aggressive because there's so many different variables that need to be looked at. They both can be more aggressive in different ways.
Anyway, the timing pull you see in VCDS isn't indicative of engine damage or a true knock event. The tiny microphone (aka knock sensor) filters a lot of noise, mainly because engines are noisy and to decipher what is dangerous and what is normal operation. The ECU knows when each cylinder is coming to TDC, it focuses on this noise per each cylinder. It was originally calibrated by the OEM based off of much testing, it is determined by engine bore, a host of other engine properties and the amplitude of the noise picked up on it's respective knock recognition graph. The OEM knows what knock sounds like, they have it dialed in perfectly. They base CF off of avoiding harmful engine knock, they have it set so that in all engine operations, pulling -12 per any one cylinder is enough to bail itself out given proper running conditions and that you're using the minimum required AKI fuel.
So let's say that 50 units of sound is a *possible* knock event, you could say that if the engine recorded 39 units of sound on cylinder 4, it would show -1.5 CF on cylinder 4. It would pull 2 units of -0.75, as it pulls timing by increments -0.75 degrees, and in the timing maps you add timing by increments +0.75. This would then in simple terms, be added to adaptation data after enough events and driving cycles. So the ECU has 16 units of -0.75 before it gets to the point where there is any potential harm.
This isn't a textbook explanation, just something I felt like writing on a Thursday morning to clear up any questions about timing pull and timing advance.
