HYDE161
HYDE16 - Project Jekyll & Hyde Build Thread
Jekyll Is Dead! Long Live HYDE!
My previous HYDE16 - Project Jekyll & Hyde Build Thread theme led me to build a daily driver while striking a fine balance between a daycare shuttle during the week (JEKYLL) and aggressive performer during cruises, highway pulls or at track events (HYDE). I’ve focused on increasing stiffness, correcting or improving suspension geometry, adding traction, and realizing better overall response from driver input while limiting NVH, rattles and feeling beat up from long drives. After studying the effects of water methanol (thanks to Jamie@APR and tech@Aquamist), I was able to safely max out the ported & polished APR K04’s power potential with direct port water methanol and the APR V3.1 100 octane software file with 93 pump gas on a daily basis. To go a step further, I tested the limits of running E85 blends as direct port water methanol allowed for enough fueling headroom in the OEM fuel system to slowly increase E85 blends, ultimately allowing me to run E50 safely on a daily basis. Ever after all of this, the K04 still showed its limitations when I was decimated by an APR Stage 3+ MK6 Golf R, and after that, I decided it was time to move up to a big turbo build. Even though it was not required for this turbo kit, I decided to have the engine built to realize the full power potential of this big turbo choice. Now I can document what was needed to attain and effectively use this level of power. This thread is dedicated to building a big turbo GTI complete with engine and fuel build by Pag Parts Turbo, Pag Parts EFR 7163 Turbo Kit and supporting drivetrain build. As the build moves forward in its final stages, I will post updates with photos in this thread and the complete chronological, step by step build photos on a daily basis on Instagram (@becauseryanjacobs) for those who want to follow the progression. Also follow my HYDE16 - The Pag Parts EFR Turbo Kit Thread.
The Pag Parts EFR 7163 Turbo Kit:
After learning that PPT was developing a complete big turbo setup for the 2.0 TSI/TFSI market, I called Arnold to hear more about his upcoming turbo kit. He explained that he wanted to provide a fully bolt on, v-banded, singe scroll turbo kit with a choice of the EFR series 6758 .64AR or 7163 .85AR turbo (both internally gated) for stock engines or fully built engines with varying software options. In our conversation, Arnold explained that he wanted to provide a turbo kit which does not require upgraded engine internals or additional fueling (reduced output software file) but had the future power potential if a customer decided to have the engine built (higher output software file) and install additional fueling options (full output software file). When reading about the countless engine builds Arnold has completed for some of the highest HP Audi & VW owners, I decided to go all out and have PPT design a fully built long block engine to realize the full potential of his turbo kit. Needless to say, I am very proud to introduce the first PPT EFR 7163 Turbo Kit for the 2.0 TSI (EA888 Gen 1 & Gen 2) platform.
Big Turbo Goals:
Aside from wanting to build a higher power “street spec” engine for daily driving, listed below, I have a few specific goals or milestones I want to accomplish over the next year or two.
-Build and develop a GTI transmission to handle this power level (see Drivetrain explanation below)
-Develop water methanol / E85 files with the use of Eurodyne Maestro 7 Tuning Suite for highest HP/TQ stats
-Slipstream Racing Event – 1/2 mile dig or roll stats
-Island Dragway – 1/4 mile stats
-Updated article in European Car & Performance VW (European Car Sweating the Details, Perfecting the VW GTI One Component At A Time, March 2015 / Performance VW Built Not Bought, April 2014)
Braking:
Audi TT RS Brake Scoops / Click Here for my HYDE16 review
Audi TTS Master Cylinder
Wilwood Forged Narrow Superlite 6R Big Brake Front Brake Kit & SS Brake Lines
Hawk Performance HB544B.628 HPS 5.0 pads
TyrolSport Master Cylinder Brace / Click Here for my HYDE16 review
VW MK5 R32 Rear Brake Conversion with StopTech 310mm Rear Rotors & SS Brake Lines
Drivetrain:
034Motorsport Street Density Engine Mount / Click Here for my HYDE16 review
034Motorsport Street Density Transmission Mount / Click Here for my HYDE16 review
42DD 6S Shifter Cable Support Bracket
Advanti Racing Storm S1 17"x9" ET45 Wheels & Bridgestone Potenza RE-71R 245/40/17 Tires
APR Pendulum Mount with SuperPro Bushings
BMC Short Throw Clutch Stop
Clutchmasters FX400 with DMFW
DieselGeek Sigma 6-Speed Short Shift Kit (black slider)
DieselGeek High Performance VW Shifter Shaft Bushing Kit
Dimple Magnetic Transmission Drain Plug / Click Here for my HYDE16 review
Driveshaft Shop 6-Speed Manual 500HP Level 2.9 Direct Bolt-In Axles
ECS Tuning MK6 GTI 6-Speed Clutch Bleeder Block / Click Here for my HYDE16 review
Fluidampr TSI Crank Pulley / Click Here for my HYDE16 review
GS Auto Solutions – Push Clutch to Start Bypass Harness
Liqui Moly SAE 75W-90 GL-4 Gear Oil
Peloquin’s Limited Slip Differential / Click Here for my HYDE16 review
Raceseng Circuit Series Shift Knob / Click Here for my HYDE16 review
Racingline (formerly VWR) Subframe Mount
Tyrolsport x ARP 02Q Bolt Kit
TyrolSport Solid Shifter Bracket Bushing Kit (SSBB) / Click Here for my HYDE16 review
USP Motorsports 1st-2nd & 3rd-4th Steel Shift Forks / Click Here for my HYDE16 review
USP Motorsports Stainless Steel Clutch Line
VW “F” Version Throw Out Bearing & NLS 02Q Shims
Engine Bay:
Audi R8 Oil Cap
Custom Powder Coated Red Valve Cover
Custom Powder Coated Alien Silver ECS Tuning Catch Can
Custom Powder Coated Alien Silver Intake Manifold
Custom Powder Coated Alien Silver Neuspeed HI FLO Air Charge Pipe
Eurocars Billet Fender Bolt Kit / Click Here for the thread discussion
Forge Motorsport Washer Bottle Filler
Grams Fuel Pressure Gauge 0-120 psi
Porsche 991 Coolant Cap
PTP Turbo Firewall Blanket / Click Here for my HYDE16 review
VW MK5 R32 Belly Pan
WhanAB Billet Aluminum Dipstick Handle
Engine Build:
ARP Head Studs
ARP Main Studs
Audi Allroad Intake Manifold
Audi Rod Bearings
Brute IX 144x21mm Connecting Rods (rifle drilled)
CP Carrillo 83mm Forged Pistons
INA Engineering Coolant Flange
INA Engineering Rear Main Seal
Supertech Inconel Exhaust Valve Set with Singe Groove Keepers
Supertech Inconel Intake Valve Set with Singe Groove Keepers
Supertech Exhaust Springs with Titanium Retainers
Supertech Intake Springs with Titanium Retainers
Tool Steel 21mm Wrist Pins
VW Main Bearings
Engine Fueling:
Aquamist 10L (2.6 Gallon) Baffled Tank / Click Here for my HYDE16 review
Aquamist Check Valve Jets & Manifold
Audi 8V S3 Direct Injection Fuel Injectors (4)
Audi Allroad Fuel Rail
Bosch EV14 Twin Spray Port Fuel Injectors (2)
PPT Custom Fuel Basket with Walbro 450 LPFP
PPT Port Fuel Injector Holders (2)
ProMeth Pulse Series Solenoid
Torqbyte 4-bar MAP Sensor
Torqbyte BM1 Bluetooth Unit
Torqbyte CM5-LT Controller
Torqbyte P3073x - Code Inhibitor Module
Torqbyte PM3 - Pump Amplifier
Torqbyte VAG Plug-n-Play Adapter
Engine Miscellaneous:
Audi R8 Coil Packs
Braille GU1R Green Lite Lithium Battery Combo / Click Here for my HYDE16 review
Dimple Magnetic Engine Drain Plug / Click Here for my HYDE16 review
ECS Tuning Billet Aluminum Oil Level Sensor Blockoff Plate (drilled and tapped for Innovate MTX-D oil temperature sensor)
FourSeasonTuning Battery Bracket
GRAF aluminum water pump
GruvenParts 2.0T Billet Intake Manifold Linkage Arm / Click Here for my HYDE16 review
Iabed Industries oil cooler kit
Motul Sport Ester Synthetic Engine Oil (5W-40 Spring/Summer - 5W-50 Fall/Winter)
Neuspeed HI FLO Turbo Discharge Pipe
NGK BKR8EIX Iridium (2668) Spark Plugs
Pag Parts Turbo Front Mount Aluminum Intercooler
TyrolSport UG Aluminum Radiator / Click Here for my HYDE16 review
USRT PeaceKeeper Heat Defense System controlled by USRT Boost Trigga
USRT TSI Oil Pressure Gauge Adapter (VW oil pressure switch & Innovate MTX-D oil pressure sensor)
VW PCV with Pag Parts Turbo custom check valve elbow connection & upgraded RKXtech PCV diaphragm
Engine Software:
Eurodyne EFR 7163 Software File (Pag Parts Turbo tuned with Eurodyne Maestro 7 Tuning Suite)
Engine Turbo - Pag Parts Turbo (PPT) EFR 7163 Turbo Kit:
Borg Warner EFR 7163 .85AR (internally gated)
PPT 3” Stainless Steel Flexpipe
PPT 3.5” MAF Housing
PPT 3.5” Silicone Intake
PPT Coolant line kit
PPT Oil feed line kit / flange adapter
PPT Oil return line kit / flange adapter
PPT Single Scroll V-Banded Cast Stainless Alloy Exhaust Manifold
PTP Turbo EFR Turbo Blanket
PTP Turbo Lava Downpipe Wrap
SPM 3” Custom Turbo-back Track Exhaust
Tial Sport MVI-2.5 Internal Wastegate Actuator
Turbosmart Kompact EM BOV Plumb Back VR1 Diverter Valve
Treadstone Performance HoneyComb MAF Mass Air Meter Airflow Straightener
VW 2.5 Bar MAP Sensor
Exterior:
deAutoLED 5500K Xenons
deAutoLED License Plate Kit / Click Here for my HYDE16 review
deAutoLED Reverse Lights
deAutoLED Turn Signals
DeutscheAutoParts Exhaust Alignment Bushings / Click Here for my HYDE16 review
Glasstopfen Rear Hatch Wiper Delete
Golf R bumper (European replica)
Painted Carbon Steel Grey Rear Hatch Assembly
Painted Silver Mirror Caps
Powder Coated Black Rear Brake Calipers
Raceseng Plate Holder with Raceseng View (GoPro)
Raceseng Rear Tug
Raceseng View
Rokblokz
SRS-Tec Rear Spoiler Addon
Tinted Rear Reflectors
USP Motorsports RFB LED Puddle Light Kit (4-Door) / Click Here for my HYDE16 review
Verus Rear Diffuser
VW European Headlights
VW Golf R LED Tail Lights
VW Highline Front Grille
Interior:
CJM Industries Vent Pod
Corbeau RRB Seats
deAutoLED Interior Cabin Lights
deAutoLED Interior Trunk Light
deAutoLED Rear Footwell LED Lights
deAutoLED Stainless Steel Seat Inserts
Double Apex Volkswagen USB Charger / Click Here for my HYDE16 review
Ecliptech Shift-P2+
German Automobile Technic E-Brake Handle
German Automobile Technik Steering Wheel
Innovate Motorsports ECB-1
Innovate Motorsports MTX-D: Oil Pressure & Temperature
Polar FIS+ Advanced (F03) MFD Display / Click Here for my HYDE16 review
ProClip USA Car Mount & Phone Holder
Raceseng Circuit Series Knob
Redline Goods Perforated Leather Shift Boot
Rennline Aluminum Pedal Set, Lifter Plate & Throttle Extension
Stinger RKXTK Roadkill Trunk Kit
VW Auto-Dimming Mirror with Homelink
VW Dash Cubby
VW Euro Switch / Click Here for the thread discussion
WeatherTech Digital Floor & Cargo Liners
Suspension:
H&R Front 26mm & Rear 24mm Sway Bars
ST Suspensions XTA Coilover Kit / Click Here for my HYDE16 review
Stern Rear Subframe Brace
SuperPro Control Arm Kit / Click Here for my HYDE16 review
SuperPro End Links
SuperPro Roll Centre Adjusting Ball Joint
Swift Rear 400lb Progressive Springs
TyrolSport DeadSet Rigid Front Subframe Collar Kit / Click Here for my HYDE16 review
TyrolSport DeadSet Rigid Rear Subframe Collar Kit / Click Here for my HYDE16 review
TyrolSport Hatch Brace / Click Here for my HYDE16 review
Unibrace UB
Whiteline Rear Trailing Arm Front Bushings / Click Here for my HYDE16 review
Special Thanks To:
apa11393, Erball, eurocars, GTR Killer, James9120, Jamie@APR, Jeff43, Jettaglis, jettaglx91, kern417, Mdhollis, RGTI13, Simmsled, tech@Aquamist, the bruce, U-20T, *****2.0t, wndwsdwngti860 and many others from the GolfMK6 Big Turbo Discussion Thread
Work Done By:
Caste Systems Performance - Norwood, NJ
Detailer’s Domain - Norwood, NJ
KMD Tuning - Saddle Brook, NJ
Linden VW - Linden, NJ
Pag Parts Turbo - Deer Park, NY
Redline Speed Worx - Washington, NJ
TyrolSport - Ridgewood, NY
Media Coverage with Photo Credit to M.Spad Photography and Mike Hyatt Photography:
Automobile Blog, How One Owner Built a 375-HP 2011 Volkswagen GTI, July 2015
CarBuzz Reader's Ride, December 2013
CarBuzz Facebook Page Discussion
Reddit, How One Owner Built a 375-HP 2011 Volkswagen GTI, July 2015
PASMAG Waterfest 23, July 2017
Special Thanks To:
Allset, Arin@APR, Bender, bostonaudi, bRett32, Bronson@APR, crew219, dasVW.com, DRedman45, GlfSprtCT1, grambles423, GunKata, GunMetalGTI, HalvieCuw, hockeystar17mnj, Jamie@APR, Jason3d, Jeff43, Jmnj, John@Unitronic, Junker, KanDyWyte, Malaki, mdhollis, Modshack, Mustache Rash, neonphase, panda_man22, Paul@DeutscheAutoParts, prospal, Quoddy, RioGrandeValley, Simmsled, Simple_John, smrtypants44, Steelcurtain, Tecni, the bruce, U-20T, Veedoubleme, Wastegate13, xola3que
Big Turbo Goals:
Braking:
Drivetrain:
Engine Bay:
Audi R8 Oil Cap
Engine Build:
ARP Head Studs
ARP Main Studs
Audi Rod Bearings
VW Main Bearings
Engine Fueling:
Audi R8 Coil Packs
Engine Software:
Exterior:
Raceseng Rear Tug
Raceseng View
Rokblokz
Verus Rear Diffuser
Interior:
Corbeau RRB Seats
Ecliptech Shift-P2+
VW Dash Cubby
Suspension:
SuperPro End Links
Unibrace UB
Special Thanks To:
Work Done By:
Special Thanks To:
