Part#?
They are standard 2.5" x 8" springs, they probably have 30 different rates available
Part#?
What pressure on hpfp is specified to you build?
I was strongly considering it as a winter project but my boiler may be leaking as of this morning which would kill those plans FAST. new boiler installed is 8-10k for would I would need /want. German engineering is expensive.
Yeah there great boiler Budarus? Vissiman?
There are other quality less expensive Italian or Irish boiler (depending on load and layout ) on the market that will save you and still get the fuel saving.
This is what I do if you need a second opinion ( since your close ) and take a look at your present " leaking " boiler LMK I can help steer you in the right direction. Bob G
Looking at a Budarus 215/4 or 215/5. The 4 pass is 10k BTUs more than my current one but I am sure mine isn't true rated capacity anymore, old and in rough shape.
I did fix it tough. Thought it was an internal leak from the chambers cooling but was just over pressure and blow off. The air valve was stuck and the expansion had no air it making it just a wasted tank. If the air doesn't hold I'll replace the tank but so far its holding.
Wouldn't mind a second opinion on which boiler/BTUs to get though.
I was just wondering seeing though as you have massive BBK's on your car, does the Enkei T6S fit over the Brakes without Spacers?
The reason why i asked is because i have Porsche boxster non S calipers with 312mm rotors and i'm curious to find out if fit over my brakes. I dont like running spacers on my car duel to road safety in Australia (Spacers) are banned!
T6s has alot of clearance, I do run outside of normal specs though so i do not know if the standard one will work on those brakes. I know mine will but dint know on the 8" wide wheels.
Mine are 18x8.5et42 and they clear the cayenne massive brakes but the will be very wide if you dont pull fenders
I ordered 18x8.5et42 ETA in a week time, my car is on stock height at the moment but i'm planning to get the car lowered by Springs & Coils..
How much poke from the guards & with stock heights do they rub on hard cornering? Also after getting the car lowered would fender screw mods work ? I dont want to look stupid with massive poke lols
Few updates to what been going on since I have not posted in forever.
Pic of the trans painted before it went in.
Some pics of the bay and overall, almost forgot cleaned up the bay a little and painted the intake as well.
Ffe force ffe force fed engeneering made it custom for him
