I doubt that fine is correct.
Kia had 1.2 million cars they lied about and only paid 300 million in fines.
Heh, my TDI will never see another dealership if they want to push this update on me. They're not going to throttle both my car's power and fuel economy to save some trees. Therefore, the only logical step now is Malone Stage 2/DPF delete/Rawtek catback, right? Right?!
^ Doesn't work like that.
Like Tom Brady in deflategate?
So, does VW have any legal loophole on the grounds that the cars pass the EPA cycle?
I can chime in here with a bit of insider knowledge. Not from Automotive, mind you. Please read it through - it's worth it if you care about this topic.
I'm not trying to say VW is innocent, but VW probably thought they were in compliance with that specification when they released the product and submitted it to the EPA. So why all the uproar at the EPA? The EPA thinks their definition of "Defeat device" is defensible in court against VW's interpretation. That is all.
RIGHT!!!! This is SPARTA!
AND, he does it again. Thank you, Mr. XGC75, for consistently contributing thoughtfully, intelligently, and knowledgeably to this forum. Also, I get a kick out of your "drives: into shit" bit every time i see it. 10/10
Not quite... 99% of the United States male population does not have a closet man-crush on VW :laugh:
So quick "diesel engine 101" for those with some questions
Diesel engines are always in a state of "rich" (more fuel then air) or "lean" (more air then fuel).
Rich conditions produce higher soot content and lean creates higher NOX
NOX is harmful to ozone.
Soot is harmful to your lungs.
To counter these effects modern TDI engines have diesel particulate filters (DPF) to trap soot and either NOX traps or Diesel exhaust fluid (ad-blue) to reduce NOX emissions.
DPF's trap soot until a certain amount is detected and then will burn it off turning it to ash. This is achieved by injecting diesel into the cylinder post-combustion - it then ignites in the DPF acting like a flame thrower turning the soot to ash and cleaning the DPF (regeneration) This also results in higher fuel consumption which is why North Americans diesels have about equal fuel consumption to gas engines
NOX traps operate in a similar fashion but require much less heat to burn off the NOX
NOX traps are now being replaced by injecting Ad-blue into the exhaust system. Ad-blue is a mixture of urea (yes, pee) and water (approx 68% water) when it injected into the exhaust it converts to ammonia and results in a NOX reduction. (Fun fact, Ad-blue fluid can be used as an ammonia fertiliser to get nice green grass)
So all this is happening very fast and being monitored by many many sensors and being helped by things like Exhaust gas recirculation, catalysts and variable engine timing all trying to reduce emissions to meet California emissions standards (one of if not the most stringent emissions standards - its the reason vw did not sell diesels in North America for 2ish years around 2007-8, they hadn't produced a system capable of meeting the standard)
Not sure what will come of all this, but I'm not really worried for Volkswagen AG.
TL;DR - suck, squeeze, bang, blow. Catch it, Pee on it, run it under a flame thrower and have computers watching all of it.
Forgive any spelling/syntax/grammar mistakes, wrote this all on mobile.
So the short answer is still quite long.
They were caught cheating on NOx emissions primarily although all emissions are in a way connected.
NOx is created when temperatures and pressures are very high during combustion. Sadly NOx emission is generally higher when your combustion is nice and hot and rapid, which gives higher efficiency (closer to the ideal thermodynamic cycle).
So In general if you calibrate the engine with a combustion recipe that atomizes fuel quickly and mixes well youll get more NOx.
There are couple of important trade-offs then. Low soot/good combustion = Higher NOx and Low fuel consumption = higher Nox.
The EPA therefore defines "clean" as having BOTH low soot AND low NOx, and since those two things are hard to achieve together it takes a good bit of engineering, and in todays world some aftertreatment to achieve it.
EGR (exhaust gas recirculation)
Particulate filters
Oxidation catalysts
and SCR calalysts (using Urea as a reactant) all are ways of reducing these combustion products while trying to maintain decent fuel consumption
But in VWs case what they did was teach the ECM to recognize when it was being tested. At that time it would switch to the "clean" map. Clean meaning that it meets EPA requirements for both NOx and soot.
Then when the test is over (and potentially an OBD drive cycle) it would fall back to its primary driving map. On the driving map it would have been optimized for best fuel economy and performance. Optimized in this case refers to the fuel injection pressure and timing, and possibly EGR and Urea flow, parameters controlled by the ECM.
Specifically earlier injection timing gives better power and efficiency but creates more NOx. NOx by the way is totally invisible and odorless.
The end result is an engine that will pass an EPA engine emissions certification test, but then will recalibrate itself for driving or (ironically) for the EPA mpg test cycle (which is done in chassis without emissions monitoring). Thus the engineers get to circumvent the very difficult trade-off between NOx and efficiency. The car will produce a lot more NOx in normal driving, and have better fuel economy. Technically not meeting the intent of the emissions law but very hard to detect.
If VW correct this via recall the car will be required to run on the "clean" calibration all the time. This will mean poorer fuel economy, I would be speculating to say by how much but VW wouldnt have bothered cheating if it wasnt a significant gain. It may even have implications on durability if certain parameters (like exhaust gas temps, turbocharger RPMs or oil life) are affected as they often are.
Nope, there were 7 other (maybe 7 total?) manufacturers cited on the independant report that rose the flag in the first place.this happened back in the 70's with the beetle. the good thing about it was that VW was accompanied by every other car manufacturer as well and it took alot of heat of of them. I would bet my left maple nut that VW isn't the only company to doing this right now.
