Is the leaking repair covered by the powerstrain warranty?
No, they do not. I don't know why, but they're fine. Mine has 86k on original pump. They probably weren't all plastic from the factory.
I have a 2011 and it looks like my water pump has just started to fail. Check coolant light flashing, fluid dropping below minimum etc. Unfortunately it appears my VIN isnt part of the recall even though Im in the 2011 to 2014 range :-(
How does it? Im out of the 60k powertrain warranty too.
I believe the Water pump warranty is extended up to 120k because it's a known issue for the GTI
It doesn't matter if your VIN doesn't come up on the recall search function. If you have a water pump issue on your MK6 GTI, it will be covered till 10 years/120k miles by VW.
