So I have a BG pump and I was able to do the code change! However, I can't tell if it's fully disabled or not..
I can checkk the binary codes for you in the AM.
EDIT: I should clarify that I don't have the two stage of just TCS then ESP.
When I do disable it, I get that ESP is disabled. However, when I turn it back on, I get "TCS/ESP is active". Before changing the code, it didn't say that when re-enabling ESP/TCS.
EDIT2: OK! so the code change DID work! I know cause as I was looking up the binary codes, I decided to switch back to my original coding, but no two stage disabling.
B6 = TCS Deactivated - TCS is Active
VS
3C = ESP Disabled - TCS/ESP is Active
