HYDE161
Had a rash of changes and we are at 26psi now on my EFR 7163.
-ZZP Opel injectors swapped out for 8V S3 / MK7 Golf R injectors (slightly less flow but better start up, idle and drivability)
-Turbosmart diverter valve installed
-Engine bay topside fuel line converted to PTFE SS -6AN line & port fuel injectors connected
-New 2-stage Aquamist water methanol layout installed (post intercooler jet vs. direct port methanol jets)
-AEM AFR gauge removed, Innovate ECB-1 installed to monitor ethanol %, fuel temp, 4-bar boost, AFR
-Neuspeed turbo outlet pipe extended to remove the OEM green o-ring gasket connection to the Pag Parts true FMIC
-All worm gear clamps from the turbo compressor outlet through the turbo outlet pipe replaced with T-bolt clamps
-Throttle body coupler worm gear clamps replaced with T-bolt clamps
-New Eurodyne file with CAM 2 timing map smoothed out, revised LPFP duty cycle MAP and revised N75 duty cycle MAP for HIGHER boost (~26psi)
-New Torqbyte GPO1 MAP to support higher boost with twin 1,000cc split stream Bosch EV14 injectors
-New Torqbyte MAIN MAP to provide cooling through the 1.2mm Aquamist post intercooler jet (triggers at 8-10psi)
-New Torqbyte GPO2 MAP to turn on the second stage of water methanol through direct port Aquamist jets (triggers at 20psi for now)
Time to continue logging and watching AFR to dial in port fuel so we can keep increasing boost levels to 30+ psi. The car is an absolute monster and I'm finally enjoying big turbo power.
Next up, 2K mile engine break in sample of Brad Penn racing oil going out to Blackstone Labs and Brad Penn’s lead engineer for results and future oil recommendations and the Ecliptech Shift-P2+ installation and review.
