DASVDUB
Sheetz, definitely sheetz.
Try the boom boom sauce
Sheetz is the sheeeeet
I came across a killer deal for Golf R front brakes; has fresh calipers, new-ish ECS slotted rotors, Hawk pads, USP SS brake lines, all hardware - all for $600. Excellent deal, but I had planned on eventually doing the TT-RS brakes in the next year or so, so I'm trying to talk myself out of it.
Is the TT-RS set that much better? The rotors are 25mm larger in diameter, and it's a 4-pot caliper. Frankly, I'm surprised that the Golf R brakes are still single-piston.
I'm thinking that waiting for TT-RS fronts and Mk5 R32 rears will be a better brake setup at the end of the day than snagging this cheap Golf R setup and staying with GTI rears.
Thanks, it's what I'm thinking too. I don't want to do a half-ass upgrade, only to wish I whole-assed it and spend more money later.Golf R brakes arent worth it in terms of an upgrade. Skip it.
Are there any other rear brake options for outside, outside of Mk5 R32? Straight bolt-ons, I mean. Not looking for 3rd party BBKs or anything like that.
Yeah, the TTRS MC was already on my kit list.Skip the ttrs brakes too. They are very heavy and not made for our master cylinder. You'll have a crap feeling squishy pedal unless you upgrade the master too. And at that point you're in bbk territory for money. Just get a stoptech st40 and call it a day.
Is the caliper block not made of aluminum? Do you know a ballpark, per corner weight of the TTRS kit with OEM rotors?
Edit: the Stoptech kit is 328mm, while TTRS is 370mm. So TTRS will absolutely be heavier, but is there a performance gain to the weight? That's a lot more clamping area.
The Stoptech kit can be had for ~$2,000, which does put it in a similar ballpark as putting together the TT-RS kit.
Edit 2: nevermind, just found a 355mm ST40 kit for $2,600.
Yes,
Paging Dasvdub
Is there a reason to not go with the Wilwoods?
