1ashchuckton
Tires add too much unsprung weight anyway.
The hot tip is to fill your tires with helium, no unsprung weight at all. Do not do the zeppelin mod, hot brakes & hydrogen goes boom.
honestly i wish i was about a half inch lower but they're not bad. handles well.
https://www.urotuning.com/products/...-and-golf-tdi-vwr31g5gt?variant=8384680362039
I’ve got them too and love them, but I’m also running the VWR sport shocks. I’m not sure how the springs are with the Koni yellows.
That’s what I figured. I also had an extra brain cell kick in and remembered most OEM clutches are organic and not highly metallic anyways. Thanks for humoring my curiosity.Probably not. Clutch plates and such are very carcinogenic. If anything they'll charge you a disposal fee
No they are still very much carcinogenicThe days of carcinogenic clutches & brakes are behind us. They have stopped using asbestos in brakes & clutches years ago.
Alot of the money back you get from recycling a downpipe comes from the platinum in the catalytic converterFor some reason I initially was linking a clutch to something like a down pipe in terms of recyclability
Probably get the same amount that you would turning something like a brake rotor in.They might take the pressure plate or flywheel but probably not going to get much for it.
I figured it was fine because I’ve heard of people running it with K04’s and stage 2. But what is this hole drilling madness you speak of?Just drill some holes into the bottom of your stock air box. The stock air intake is actually quite good.
