P
plac
Guest
since you are very familar with GTI fitments.. would the Pioneer TS-PRS720 mid fit in the 2011 GTI? Thats my favorite speaker of all time.
that is very interesting. do you pics of waht you did? becuase i know from personal experience that most beefy and powerful midbass have that issue.
if you use a 1" spacer, how far is your surround from the door grille? is it possible that your door grille is hitting the surround with out you knowing it? a quick chaulk test will confirm.
refer to this thread for waht i mean:
having spent over 3 hours just trying to get a set of Arc audio black series to fit into the door of another mk6, with measurement up on measurement, find routing it to make it thinner to make it work, i am surprised you an so easily fit a normal 6.5" with a 1" spacer....beuacse a 1" spacer is what i started with and the surround hits the grille on excusion. i ended up with a 7/8" spacer and shavbed the grille a lil for that to work.
http://www.diymobileaudio.com/forum...y/131634-2010-golf-mk6-oem-hertz-bit-ten.html
in either case, my point was never that other midbass are unfittable, but this is a sure fireway to easily fit a mid that has the output performance, the impact and extension, without having to spend time worrying if it will fit and carefully crafting a spacer with precision.
