Boscogn
What did u go with?Why did I wait so long to do an intercooler? Car is so much more enjoyable.
Sent from my SM-G950U using Tapatalk
Quick, stupid question.
When using the crank pulley hold tool to replace the crank pulley, do the nubs on the tool hold the pulley against something else behind the pulley? I.E. does the hold tool mechanically link the pulley to the crankshaft?
Then I suppose I don't understand how it's supposed to work, other than giving a counter torque to remove/replace the bolt.No it doesn't. Just prevents you from spinning/turning over the engine while torquing it and making sure you keep your tdc marking aligned.
If the pulley can still move freely, I don't know how to be sure that the pulley is in the proper position, relative to the crankshaft, when I replace it. No idea why the tool wouldn't lock the pulley and crank together - that's the most logical.
Edit: It doesn;t even link the damper pulley to the chain pulley?
Never mind, I just realized that the pulley has teeth on the backside. This whole time I thought it was flat and I could not wrap my head around the pulley staying in-line with the crank.There's a TDC marking on the pulley, and on the timing cover that you line up first. Then you hold the pulley in that position with the counter hold tool while you torque the bolt.
I got it, man. Thanks.
I see what you're saying, thank you.There's one tooth that is different than the others, however you absolutely must make sure you line up the TDC markings on the pulley/timing cover and not just the tooth with the matching tooth on the crank side.
I was definitely planning on using some of the sweet blue stuff. Thanks for the additional input!You don't need to worry about TDC unless you're removing the chain, even then there are markings to guide you. If you jack up the car just right, the holder tool will rest on the ground and do the work for you. The pulley itself is fool proof, it will only fit one way even if you turn the crank. Put it on by hand, you'll feel the engagement. Then the trick is getting the bolt started. I would recommend some blue loctite unless you are super strong. The torque spec is really high.
Different question: can anyone tell me the difference between the Low-Line grille and the R-line grille? From my super expert and technical research of looking at many pictures from Google searches, I cannot tell a single difference other than the obvious "R" badge.
Look at the front on pictures here:
https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/golf-r-upper-grille/5k0853651bf041/
https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/front-grille-low-line/5k0853651alqwa/
subtle differences, R grille has a bit less rounded bits and horizontal notches line up a bit different.
How come the US Spec and Euro Spec golf R bumpers are different? US has a horizontal slit under the licenses plate holder where as Euro doesn't? Does the US spec have something that goes there?
